Sixth Gear
Old 05-25-2011 | 07:48 AM
Grind's Avatar
Grind
Forgot to add: OE tires at rec. pressure.
  #52
Old 05-25-2011 | 09:11 AM
tonygret's Avatar
tonygret
My 06 Ultra literally screamed for a sixth gear. But in 07 they not only added 6th but re geared the trans in 1 through 5. In my opinion the gear changes 1-5 were enough, but I think that they got so much flack about not having a 6th they threw it in anyway. Most bikes don't have a 6th and don't need it. My BMW pictured below does just fine anywhere over 100MPH mark with only 5.
  #53
Old 05-25-2011 | 09:21 AM
cjlandry's Avatar
cjlandry
I tend to use 6th gear at lower speeds, like 60 on a straight, flat, open road. After reading this thread, particularly the part about fuel economy, I think I'll try staying out of 6th unless I'm running over 70 on a straight, flat, open road.
  #54
Old 05-30-2011 | 07:23 AM
Diesel2's Avatar
Diesel2
My owners manual says to shift from 5th to sixth at some 85 km's which is like 55 mph . I may shift at anywere from the 85 [55 mph] up to 100 km's [62.5 mph] rather then the 85 km's. If on level road and see no need to pass and only one up etc., then I will shift then. Keeps the revs down and fuel mileage up. Depends if I see some reason that I may need to get on it then will stay in 5th other wise I run in sixth gear. Now if I were hot rodding, then say 130 km,s plus before 6th.
  #55
Old 05-30-2011 | 10:07 AM
WildBill76's Avatar
WildBill76
Around 60 mph. I have an FXDI. I am sure if I had a passenger or a heavier bike, the speed would be greater.
  #56
Old 05-30-2011 | 10:23 AM
WildBill76's Avatar
WildBill76
I have ridden the mountain highways in sixth gear no lugging. The speed limit was 70, and the flow of traffic was 70 plus mph. I have made some trips where nothing was slower than 85. ( Go with the flow or get ran over. Look out for big rigs on the downslope.)
  #57
Old 05-31-2011 | 07:39 PM
StrokedNBored's Avatar
StrokedNBored
Only above 65 when actually on the throttle... Any less and the engine just sounds like it hates life.
  #58
Old 06-01-2011 | 06:44 AM
Robert Le Gras's Avatar
Robert Le Gras
I've done the same. I think it really works very well if you can keep the speed 70 and above.
  #59
Old 06-01-2011 | 09:06 AM
archergodwin's Avatar
archergodwin
No problem on the flats @60 on up.... hills @65.. also no problem...
JONNIEROCK
07-23-2019 05:49 AM
2013superglideseattle
Milwaukee Eight (M8)
20
08-13-2017 08:33 AM
TORQUEY
09-22-2010 09:46 AM
Urban Coyote
09-03-2007 09:47 PM
rjw54
06-03-2007 05:14 PM
Quick Reply: Sixth Gear
