Sixth Gear
Old 04-12-2011 | 10:54 PM
JekyllnHyde's Avatar
JekyllnHyde
Someone said whatever feels good to you. Everyone has different riding styles. Some run consistently at 3000 rpms other prefer 2500 and some maybe in the 2200 range. I myself use 6th gear as low as 65mph on the highway on a long stretch with open road, in heavier traffic I'll stay in 5th.
  #42
Old 04-13-2011 | 04:50 AM
dano8855's Avatar
dano8855
75+ on level highway...I really don't get much use out of 6th gear
  #43
Old 04-13-2011 | 04:53 AM
Brawny MMC's Avatar
Brawny MMC
65 + for me mostly highway.
  #44
Old 04-13-2011 | 08:57 AM
Mk1Racer's Avatar
Mk1Racer
I keep trying to, but it's not working! I would like to have it for 65-70 mph plus runs on the highway. That said, my bike runs fine in 5th up to ~95. And while I'd like to have it, I can think of better ways to spend that $5k.
  #45
Old 05-24-2011 | 10:02 PM
Grind's Avatar
Grind
I just got back from a long road trip. Heading home, across boringly flat Indiana, I turned on the ghetto-cruise and got the throttle set just right to hold steady speed (70mph) in 6th. Then, I kicked it down into 5th, to see what would happen. I had a feeling that 5th might be more efficient. Without touching the throttle, after downshifting, my speed would creep up. I'd get the throttle set just right again, and shift back to 6th. Sure enough, speed would bleed off.
All along the trip, using 6th, I had been getting ~40mpg, consistently. For the last leg, I didn't use 6th and got 44.12 mpg.
Honestly, what is 6th gear needed for?
  #46
Old 05-24-2011 | 11:02 PM
Ole T Sport's Avatar
Ole T Sport
Depends on mods. Downshift to 5th at 60 and upshift to 6th at 65. Using Stage II with bagger cams with low end toque. Love the Limited.
Always thought revving 3 grand at just over 60 in 5th with my FXDXT-Sport was a bit much.
  #47
Old 05-25-2011 | 01:14 AM
Squirrel67's Avatar
Squirrel67
When my bike hits 6th the old Judas Priest song "BREAKING THE LAW-BREAKING THE LAW" is running thru the ole noggin.
  #48
Old 05-25-2011 | 04:49 AM
nigelgeast's Avatar
nigelgeast
Talking 6th gear
You dont say what mods you have if any. you dont say what happened to your rev's, it sounds to me like you need a bit of tuning with more torque possibly around 3k rpm which would give you more omph and then the benefit of the 6th gear would come into play.
  #49
Old 05-25-2011 | 05:09 AM
11bDad's Avatar
11bDad
Took a 1100 mile trip last week, with 190 miles one way on the interstate to our base camp for our mountain riding (Blue Ridge). At 70-75 on the interstate, with a windshield and approx 30 lbs of luggage, my 2010 FXDC made 49 to 51 mpg. Only mods are a pair of XIED's.
  #50
Old 05-25-2011 | 07:43 AM
Grind's Avatar
Grind
Screamin' Eagle slip-ons, windshield, 25lbs of luggage, no tuner. Followed my buddy who had honest-to-goodness cruise control set at 70. In 6th, the slight terrain changes required a lot more throttle opening then when in 5th, for the very minor fluctuations in speed. I don't have a tach, so I don't know what revs I was turning. 5th was silky smooth purr at a crack above idle, 6th would get lumpy, chuggy on anything but absolutely dead flat where more than just a crack past idle was needed.
Quick Reply: Sixth Gear
