Front end wobble
Old 04-10-2011, 02:38 AM
Krazy8s's Avatar
Krazy8s
Krazy8s is offline
Default Front end wobble
Gave myself a bit of a fright yesterday. Was rounding a nice long right hand sweeper bend at about 55 mph, touched the front brake lightly to take some edge off my speed and the front end started wobbling like mad and continued for a bit ( 3-4seconds) after I let the brake off. First time it's happened.
Anyone else experience this and where could I start looking to perhaps find a solution?
TIA, 8's
Old 04-10-2011, 03:50 AM
Foxster's Avatar
Foxster
Foxster is offline
Before the "you have to spend a $gazillion on something" people pipe up, just check the front wheel's fallaway as per the manual
Oh - and checking the tyre pressures wouldn't hurt.
Old 04-10-2011, 04:15 AM
Krazy8s's Avatar
Krazy8s
Krazy8s is offline
Tyre pressures are good, checked before I went out and again on return, was the first thing that came to mind.
Thanks for the fall away tip, will look at that ASAP.
Old 04-10-2011, 06:34 AM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
Most motorcycle safety courses recommend against using the front brake while turning ... take off speed with the front brake before going into the turn ... if needed, use the rear brake while in the turn ....
R/
'Chop
Old 04-10-2011, 06:35 AM
2011Deluxe's Avatar
2011Deluxe
2011Deluxe is offline
Big mistake.
Old 04-10-2011, 06:41 AM
howitzer88's Avatar
howitzer88
howitzer88 is offline
Originally Posted by thegrants82
Big mistake.
+1. Basics.
Old 04-10-2011, 08:10 AM
stic2it's Avatar
stic2it
stic2it is offline
+2, I did a face plant on the pavement after I hit the front brake in a turn! Lesson learned, only touch the rear brake in a turn, stand the bike up if you have to apply anything more than a touch!
Old 04-10-2011, 12:29 PM
dynabobster's Avatar
dynabobster
dynabobster is offline
There is a big difference to grabbing a handful of front brake in a corner to feathering the front brake in a corner, but that is not the real issue. You should not get any wobble when braking period.
Krazy8s, do you get and sort of wobble when lightly applying the brake in a straight line or at any speed in a straight line? Besides checking the fall away, I would take it to the dealer and have them make sure your rotor is torqued properly, check to see if there is excessive runout of the rotor with a dial indicator, check to make sure the bearings are not loose/failing and that the axle is properly torqued.
Old 04-10-2011, 12:38 PM
SURFOR Chop
Maybe check for a warped rotor, too ....
Old 04-10-2011, 12:49 PM
Mi3ninos's Avatar
Mi3ninos
Mi3ninos is offline
Received 1,762 Likes on 700 Posts
Tires first (wear) then pressure then fall away then bearings neck and wheel
Quick Reply: Front end wobble
