won't start after run out of gas !
Old 04-09-2011, 08:03 AM
Coxbow's Avatar
Coxbow
Coxbow is offline
Default won't start after run out of gas !
Hi Folks,
yesterday I've ran out of gas with my wife's XB9S, this morning I put a bottle of gas in it; won't fire up, I phone my indy who's saying that I've got to put more gas, did it, still won't start !
any ideas ?
Thanks
Old 04-09-2011, 09:40 AM
05dyna88's Avatar
05dyna88
05dyna88 is offline
It will take a while for the gas to get to the carb. Try a little starting fluid to help
Old 04-09-2011, 10:22 AM
Coxbow's Avatar
Coxbow
Coxbow is offline
it's a fuel injection ;-)
Old 04-09-2011, 11:11 AM
tomzilla's Avatar
tomzilla
tomzilla is offline
Is your pump coming on when you turn the bike on? If not check relays
Old 04-09-2011, 12:16 PM
nevil's Avatar
nevil
nevil is online now
Received 1,036 Likes on 774 Posts
If there was a little bit of crud in the bottom of the tank it might've gotten sucked into the line or filter when the gas level dropped.
Old 04-09-2011, 12:27 PM
8541hog's Avatar
8541hog
8541hog is offline
Pull the fuel line off the throttle body and point the end of it into a can (big one) then turn on the ignition and see if it sprays fuel into the can. If not she is clogged somewhere or the pump is not working.
Old 04-09-2011, 12:51 PM
lkohan7373's Avatar
lkohan7373
lkohan7373 is offline
I agree with what's been said. Most likely some crud in the filter. Check the filter and if so replace it. It keeps the crud out of your injectors.
Old 04-09-2011, 05:09 PM
Other Sheep's Avatar
Other Sheep
Other Sheep is offline
OK, I give up. What the hell is an XB9S?
Old 04-09-2011, 05:16 PM
evanstock's Avatar
evanstock
evanstock is offline
Buell Lightning I believe.
Old 04-09-2011, 11:53 PM
HemiOrange's Avatar
HemiOrange
HemiOrange is offline
How new was the gas that you put in? Bad gas has caused me too many problems and I'm not talking intestinally.
Quick Reply: won't start after run out of gas !
