Sluggish then High Idle
2005 Wide Glide, Stage 1 intake, V&H Big radius 2 into 2, Power Commander III USB. Got a full tank of gas, while riding started getting sluggish with bad throttle response. I Parked the bike over night, got up to ride again but this time the idle sounds almost double what it should be. This bike does not have a tach, but I know the idle is way to high. Any Ideas what may have happened or what to do to fix this. Any info is helpful.
Thanks, Devil
Thanks, Devil
Okay After removing my PCIII there was no change...So I thought lets look around the intake and see what I find. (Looking for leaks or loose wires) No loose wires but there is a huge air leak between the intake manifold and the throttle body. The 2 screw came out and lost the O ring... Got new ones can wait to get home and put them on. I will keep you all posted.
hitman1267
08-30-2016 03:30 AM
KRUSE
07-02-2008 05:17 PM
