Hole in Head pipe
Old 03-28-2011, 12:46 AM
otter8's Avatar
otter8
otter8 is offline
Default Hole in Head pipe
Question for you about head pipes. I have an 02 FXDL and there is a hole in the head pipe before you get to the slip on muffler.
Will that affect the performance of the bike? Are they hard to uninstall and install? Where can I find good ones that won't break the bank.
Old 03-28-2011, 08:27 AM
SuperFastGlide's Avatar
SuperFastGlide
SuperFastGlide is offline
holes in exhaust other then at the ends lol are never a good thing... look at ebay, theres tons of fair priced pipes for your year model bike... pipes are very easy to change... dont forget to get some new exhaust flange gaskets...
Old 03-28-2011, 12:42 PM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
You're not referring to the crossover tubes ...? Were they cut off of your bike and left open to the atmosphere ...?
Old 03-28-2011, 04:35 PM
otter8's Avatar
otter8
otter8 is offline
Not sure what a cross over pipe is not it wasn't cut off the hole is on the underside of what is number 23 near number 24 in the picture.
After I replace these do I need to have the bike re tuned?
Old 03-28-2011, 04:41 PM
8541hog's Avatar
8541hog
8541hog is offline
If you do a direct replacement (same type), no tuning is needed.
You could also pickup some muffler repair tape at your local auto parts store for a cheap easy fix.
Old 03-28-2011, 04:52 PM
otter8's Avatar
otter8
otter8 is offline
Thank you... I will try the tape until the income tax check arrives.
Old 03-28-2011, 05:04 PM
SURFOR Chop
Red circles in diagram show the two parts of the crossover pipe that fit together to vent each exhaust header with the other to take advantage of scavenging effects ... one of the touted effects of a 2-into-1 exhaust ....
This improves lower RPM responsiveness by emphasizing low-end torque ....
The crossover fits together below the transmission cover on the stock pipes ... behind the front headpipe as illustrated above ....
R/
'Chop
Attached Thumbnails Hole in Head pipe-02-fxdl-exhaust.jpg   Hole in Head pipe-05-fxdi-exhaust-x-over.jpg
Old 03-28-2011, 05:58 PM
PhillyKid's Avatar
PhillyKid
PhillyKid is offline
I got a complete set that I just pulled off my 2010 fatbob at the 1000 mi check up.... I would be willing to give them to you for cheap... got the original ac back plate with air cleaner also....
Old 03-28-2011, 06:23 PM
tomzilla's Avatar
tomzilla
tomzilla is offline
pm sent
Old 03-28-2011, 06:34 PM
tomzilla's Avatar
tomzilla
tomzilla is offline
philly kid, your inbox is full, im intrested in the exhaust if you still have em
Quick Reply: Hole in Head pipe
