Will a Lowrider fender fit a Fatbob
Hi Guys,
I am looking for information on how to fit a Lowrider fender to my Fatbob. I know a lot of guys are fitting the '10 Wide Glide fender (it looks easy, and the fitment is perfect) but I really like the look of a more wraped fender like the Lowrider.
There is a post with a forum member that did this, but there is no info on wether it just bolts on, or if I am going to have to split the fender to add an inch.
Thank you for your input and help. John
Hi Guys,
go ahead and do it Jonn.
at the very worst you split it and add some width.
in 2008 I measured and come up with same width between struts.
butt I was called out as being wrong on the measuring.
I am pretty sure I will have to use spacers at the very least. I dont really want to split it since I dont have a shop since I moved to San Jose and would have to farm out the work and would rather spend my money elsewere.
I was hoping to see some examples of others work to see how the end product looks.
on my 006 FXD the fender is 8 1/2" at the rear
at the front mounting point - 9"
keep in mind the fender will stretch out
sounds like you may not even need anything more than the stock spacers.
butt, also need measurement between strut mounting points (front to back)
The number one reason I want to go with a lowrider or perhaps a standard Street bob fender is the way it looks after it is set up to accept detachable bags. Since I like to run with bags as much as I like to not, a detachable setup is the way the go.
The '10 wide glide fender looks silly to me when you move the turn signals to the rear and back of the fender. (Almost looks like bright red ears too high on someones head.) The Lowrider fender gives me the option to move to a single all in one turn, stop, tail light that looks nice and clean when installed.
FYI, since I dont want my Harley to look like a dirtbike, I wonder how it will all fit once I lower this bike with some 11" progressive HD shocks.
I am hoping these thoughts will help you guys with your responses and advice as I begin to move forward with this project.
Yea, an inch is what you need.
I don't know if I'm the guy you're referring to but I did the 'split a fender' thing in 2009. The cost of the materials alone exceeds the price of the new WG fender and there’s no other 'direct bolt-on fender' in the Dyna family for the Fat Bob.
There are better ways to accomplish your goal.
The best way (i.m.o.) would be to get a 9” wide blank fender with no holes. You could mock it up as you needed/wanted with the shocks you plan to use.
That would allow you to set the fender a little ‘higher’ on the struts for a more assured clearance between the top of the tire & bottom of the fender (the Heavy Duty shocks with their 'stiffer' ride wouldn't be necessary).
Just keep in mind that because the seat mounts to the fender… the raised fender will move the seat towards the tank so make sure to include it in the mock up process. Once you have those two steps finished you could move to the fitment of the tail light, signals & license plate and arrange them how ever you like.
Speaking of struts on the Fat Bob, as to their length they are the same as all the other Dyna’s... that’s also true of the bolt pattern, i.e. the distance between the mounting holes. The only difference is width. So any stock Dyna fender will 'bolt directly' to the Fat Bob struts.
If you go the stock full length Dyna fender route I’d suggest trying the ‘stretch’ method… which should work. If not add the spacers as needed.
