belt tension?
belt tension?
Hi all. Yesterday put passenger peg mounts on, and had a heck of a time getting the ratchet around the belt. So I was pushing the belt up and down with my hand to try and get room to swing the ratchet. When I got done it just seemed to me the belt felt looser. Is there anyway the belt lost tension because of that. I didn't mess with anything besides the bracket and pushing up and down on the belt. Just dont want anything out of alignment or loose. I checked with my finger. Moved roughly half to 3/4 of an inch. This something I should be worried about? Thanks all
Belt tension won't change just because you fiddled with the belt. They are quite slack on some bikes, even when tensioned correctly and if you pulled on it you likely got all the slack to move round to the top or bottom of the belt.
Its worth checking the tension regularly though, gets expensive when they break...
Received 49,734 Likes
You are just stronger from working out. Stronger you are the looser the belt will fill. Guess thats why they make a gage. I always do the it fills OK. Last time I checked at 40K the belt appeared to be sort of bumpy looking. The rear sprocket looks that way also. I scratched it with a scribe. Appears all the hard chrome wore off. Dealer said they rarely replace belts and never pulleys. Not sure whats up with that but I may have been running it too tight. Also the interstate were I drive daily is grooved concrete and a lot of grit is thrown up. Guess when it slips back there I will replace it all and get me a gage. Will I need to replace front sprocket?
