Harley 103 stage 4 upgrade
If it's no secret, just what was done? Bore kit make, throttle body size, heads, cams, pipes, air cleaner, et al.....
Those are the numbers that I hope I have, just need to wait for the dyno tune.
Oh, have you smelt that ugly odor of burnt clutch yet! Check out AIM's variable pressure clutch.
If a tuner knows what he is doing, breaking a bike/new build in on a dyno can be done FAR more effeciently and safely on a dyno. He can keep track of the engine's temperature, fuel tables, and timing.
Check out Motoman's method for breaking in engines. If done under heavy accelleration and engine braking, the rings will seat before the first 100 miles. The first 25 to 50 miles are critical for having an engine that makes power to it's full potential. The secret is to keep those rings under constant pressure, either under accelleration or hard engine braking.
The window of opportunity is short. Baby the engine early and it will never be a strong runner.
True and all but have you ever noticed how a Harley loosens up after a coupla thou miles? There is more to it than rings if its on new bores and pistons. Back in the day when we used to dyno as soon as possible we would always re-dyno them after a few thousand miles and then get extra HP and sweeter running, now I just dyno at 2,000 miles, saves money :-)
Screaming Eagle Pro Stage IV kit-103 Cubic Inches (pg 25 option C.)
Here’s a 103 cubic inch racing kit that puts it all together for
you. If your looking to build a fast, track-ready, 103 kit and
want to buy all the components you need to maximize your
results, here’s the kit! T his eliminates the guess work on what
components you should use and what works well together.
We’ve put all the components together including SE performance
heads that provide a great performance upgrade
for a 103ci at a very attractive price. Kit includes our highperformance
/ high-flow Screamin’ E agle
® Performance
110+ Heads which include large intake valves at 2.120" diameter
(our biggest ever), high-compression forged aluminum
10.5:1 pistons matched to the 110+ heads, an SE260 cam to
open the valves appropriately, allowing the right balance of
air and fuel to enter, Perfect-Fit Pushrods to accommodate
the higher cam lift, a 58mm E FI throttle body to get that air
flow to the heads, big 3-7/8" diameter highlighted cylinders,
then topping off this kit off with a “must have” Super T uner
to provide the right tuning capabilities. Kit includes gaskets
27516-08B Black. $2,399.95
Fits ’07-later Dyna
®, ’07-later Softail® and ’07 T ouring
models. Not compatible with cruise control.
