Bates replica headlight
I'm trying to add a Bates replica headlight from V-Twin. Its 4 wires. White, blue, green and yellow. If I take the stock wire plug out of stock headlight will it work properly in with the new one?
I tried the search feature first.
Not sure why the Bates light would have 4 wires ... the wiring diagram for my '05 FXDI only has three wires (white, yellow and black) ... low-beam, high-beam and ground ....
You will probably have to test the new headlight wiring to determine which wire does what ... then mark them and either solder or crimp them to your existing headlight wiring or you could crimp on AMP-type sockets and use the original connector and plug it into the harness ....
[Reviewing the diagram just now, on international bikes, there is a fourth (orange/white) wire for a "position lamp" ....]
Found out.
Blue is Hi beam, White is Low beam, Green is Ground and the Yellow is for the high beam indicator light on top of the bucket. I suppose you splice the Yellow to the Blue.
