Clutch cable replacement
Old 03-11-2011 | 05:13 PM
kirk180's Avatar
kirk180
I didn't look to see what V&H exhaust system you have...but I had to take off my big shot staggereds to get to the clutch cable on my 2010 fxdc.
Old 03-11-2011 | 06:24 PM
CHiPZ's Avatar
CHiPZ
6th Gear
I was looking over the procedure today, because i have to replace mine. Looks pretty simple.
Originally Posted by 8541hog
DO NOT remove the retaining ring on the clutch arm in the trans cover, all you have to do is remove the cable from the hand control loosen the adjuster all the way and you can undo the trans end without removing the ring and plate.
I was thinking that when I looked over the procedure.
rhd01
02-14-2016 06:04 AM
NOLAcustomFATBOY
07-18-2011 07:26 AM
HDF Tech
12-27-2005 09:13 PM
RCNewton
07-01-2005 02:52 AM
HDF Tech
06-30-2005 09:22 PM
Quick Reply: Clutch cable replacement
