Who's running a 110/90/19?
I have an Arlen Ness front fender so I dont know if it will rub on the stocker. Every tire manufacturer (should) list the inflated tire width in cm or inches. I know that DennisKirk lists the specs. Just keep in mind that EVERY tire is different. For example, I am running an Avon 90/90/19 and it is about 4.1 inches thick. You may find 100/90's out there with the same thickness. Save your self the headache and measure before you order........
Thanks for all the responses. I’m either going with the Avon Venom or the Metz 880, since you all said those would fit. I’ll let you know in a couple weeks - I've got to wait for the weather to turn bad again to work on the bike. Besides replacing the tire, I’m replacing brake pads, fork oil-seals, and adding Ricor Intiminators.
Running a Dunlop D404 110/90x19 on a 2009 Super glide custom. I am running a stock Dunlop k591 160/70 b17 on the rear both tires have the same tread pattern.
lots of room under the finder but if it rains the narrow finder might not stop the tire from slinging a little water! This tire fills the fender out to the edge it covers But not close to touching anything. I don't ride in the rain if I can help it. More rubber on the road, what is there not to like.
