Step by step 21" front on SB "LOTS OF PICS"
UPDATED!!
1st if the pictures don't work please let me know.
Anyways I have been putting this off all winter then it is starting to get nice so I take the scoot out for a spin then start the mod of changing the 19" front SB wheel to a 21" front. I bought the rim from Jireh cycles and got it in three days. Follow the pictures and it will explain all. Take off old wheel (loosen two allen bolts, and the axle nut), get the old tire off (free at my indy if you buy tire there), using the correct hex bit I unscrewed all the spokes, wiped down with oil and hit all the threads with oil, then usings https://www.hdforums.com/forum/dyna-...nd-spokes.html advice of every 4th hole laced the spokes into I went to town. Doing this by hand took about 2.5 hrs for everything and I even missed up. I put the spokes in the wrong place, causing them to be to long. However, ten minutes of unscrewing and moving the spokes fixed this.
This is really easy to do and worth the $45.74 I paid for the 21x3.25 Jireh rim, using my old 19" SB chrome spokes (they are still perfect), and 2.5 hours of work. I am having my indy "true" the wheel and install a 120/70/21 tire. With the truing, tube, tire, it will cost me $155, so I'll have a new 21" front tire for $200 bucks! Awesome deal.
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7: Incorrect Lacing!!
Step 8: Correct Lacing, now for tire!!
Here is the final product
Close up with fender adjusted, No rubbing on the little 5 mile test trip.
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Last edited by rebelranger; 03-07-2011 at 03:57 PM. Reason: Add pictures and update!
