Cross over hose after tank lift
Old 02-28-2011 | 09:09 PM
trappermarc's Avatar
trappermarc
Default Cross over hose after tank lift
I installed a 2" tank lift from jackyl. It really seams to pull on the crossover hose. I bent the tubes a little, and it helped, but i'm worried. Anybody else have this problem? Maybe it will be okay. Heres some pics.
Attached Thumbnails Cross over hose after tank lift-img_0594.jpg   Cross over hose after tank lift-img_0595.jpg   Cross over hose after tank lift-img_0596.jpg
Old 02-28-2011 | 09:15 PM
PiP's Avatar
PiP
go to auto parts store and get some longer fuel hose, pick up some hose clamps as well.
Try and do it when the tank is empty, but you knew that.
Old 02-28-2011 | 09:36 PM
SteveO-ll's Avatar
SteveO-ll
Yup! What he said. You got to replace the hose with a 1/2" to 1" longer hose to give it a little slack, plus two hose claps (I used the stainless type).
Old 03-01-2011 | 05:44 PM
Coxbow's Avatar
Coxbow
i've got the same tank lift, but delivered as a kit, with a longer hose, works perfectly...
Old 03-01-2011 | 06:34 PM
Smitty79's Avatar
Smitty79
Same kit, had a longer hose in it. Make sure the tank is empty... I mean as close to bone dry as possible... Then just replace the old one and you will be set.
Old 03-01-2011 | 06:42 PM
blacknsilver's Avatar
blacknsilver
Yep, get a longer hose. I wouldn't bend the tubes though they might snap off.
Old 03-01-2011 | 07:53 PM
rjsimmons's Avatar
rjsimmons
Still using the OEM line on my WG after a 2" lift. No problems, works fine. Eventually I will replace it with stainless but I need some chrome clamps first...
Old 03-01-2011 | 08:15 PM
ghostrider69's Avatar
ghostrider69
When I had Jackyl's 2" lift on my bike I used the stock hose. It was up against the frame like yours but never had any problems with it.
Old 03-01-2011 | 08:26 PM
animalnoll's Avatar
animalnoll
I used Jackyl's 2" lift, also. My tube looks like yours, also. I have had no issues with it. Doesn't it make it right, but if it ain't broke don't fix it.
Old 03-01-2011 | 08:36 PM
FXBadass's Avatar
FXBadass
Thanks for sharing your bike pic in your sig, it's awesome!
Quick Reply: Cross over hose after tank lift
