snapped exhaust stud!
Well my new pipes showed up over the weekend so I decided to run out to the shop and pull the old ones off. The first three header nuts came off no problem. The last one (the one on the front head behind the frame tube) felt a little tight and before my brain could stop my hand I snapped the stupid thing off flush. I'm pretty sure unless my local shop has some special tool or method of drilling those out with the head still on the bike I'm gonna have to pull the head. What a bone head mistake. I've never torn down a harley motor and I'm thinking I'll just load the whole thing up and take it to my indy and let him mess with it. Anyone ever had this done? It's a shame I don't have the coin for a big bore kit... be a good time to just tear the whole thing down.
broken flush is easier to drill out.
You can do it yourself. Just center punch the middle and drill it making sure no to go too deep. Steady hand with a small drill should do it.
Drill size should be one size less the actuall tap drill size. and just run a tap in it with some good tapping oil and air hose to get the chips out.
Just don't go too deep.
Get a new studd first and you will see how much thread and what size you need.
There's lots of good info on this forum on how to remove that stud. I like PKellyMC's idea on posts 10 and 15 of this thread. Do a search on exhaust stud and you'll find lots of good stuff. If you decide to do it yourself and try using and EZ-OUT, just make sure to use the largest one you can, take it slow and easy and use lots of penetrating lube (not WD-40).
Good Luck!
Good Luck!
XanderWild
Exhaust System Topics
11
04-05-2013 02:27 AM
