Carburator Cough
Carburator Cough
Not very often, but every now and then with the quick rollback on the accelerator, I'll get a sharp cough out of the carb area. Sometimes its enough to stall the bike starting out.
Once the bike is warm, it idles great and accelerates very quickly as well, but I do get some popping on the decel. Are these two related?
I'm thinking maybe the carb needs a bit of tweaking, but not sure where to start in diagnosis. Haven't really investigated thoroughly, as it only happens every now and then, but thought I'd see what you guys had to say about it.
Thanks.
Thanks.
Received 4,838 Likes
If the carb was set up for the engine mod, then yes you are lean. Adjust the air/fuel needle out 2 1/2 turns from lightly seated. Either raise the needle with two #4 brass washers or replace with a sportster carb needle, the part number escapes me right now.
Found the number--H-D part number27094-88. The needle is a tad richer at idle to 1/4 throttle.
http://www.harley-performance.com/ha...arburetor.html
read through this and also the other articles they have. I highly recommend getting their kit vs a couple washers on your needle. Very good chance you will need to change out the 45 low for a 46.
Thanks again for the advice guys. I took Rounders advice and bought the kit from CV. Hopefully it will get to my house by Saturday so I can get working on Sunday. I did have one question. The kit comes with 4 jets, but it doesn't say which ones? Since it asks for the type of motor, I'm assuming that they will send the stock size and then maybe the next size up?
