weight loss/power weight ratio
Old 02-25-2011, 05:48 PM
ged533's Avatar
ged533
ged533 is offline
Default weight loss/power weight ratio
instead of motor build went with weight loss.alloy swingarm,ceramic brakes for unsprung weight.expensive but works found this battery 11lbs lighter than stock twice the lifespan seems like a good investment.on backorder will post when arrives.169.95 delivered at motomummy.com
http://www.shoraipower.com/s-57260-FXD-Dyna.aspx
Attached Thumbnails weight loss/power weight ratio-002.jpg   weight loss/power weight ratio-005.jpg
Old 02-25-2011, 05:52 PM
TORQUEY's Avatar
TORQUEY
TORQUEY is offline
Fascinating. I never would have believed that a battery could save 11 pounds!
Old 02-25-2011, 06:31 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
What swingarm?
Old 02-25-2011, 07:48 PM
AFONE's Avatar
AFONE
AFONE is offline
Great find....easier than shaving 11lbs off my gut!
Old 02-25-2011, 07:52 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
You won't be able to tell any difference in performance, w/ these upgrades.
Old 02-26-2011, 02:45 PM
rockon's Avatar
rockon
rockon is offline
Who makes the swingarm?
Old 02-26-2011, 03:15 PM
redrubicon2004's Avatar
redrubicon2004
redrubicon2004 is offline
Try telling that to drag racers!
Old 02-26-2011, 03:21 PM
KYFATBOB's Avatar
KYFATBOB
KYFATBOB is offline
Exactly!!! When I use to drag race quads on dirt, the general rule was take 15 pounds off and you would gain a 10th of a second. And that was only running 300 feet. Less weight equals going faster!!!
Old 02-26-2011, 03:27 PM
ged533's Avatar
ged533
ged533 is offline
metmachex quality is excellent about 20 lbs weight loss
http://www.metmachex.net/p0_0_0.htm
Old 02-26-2011, 03:58 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
Originally Posted by KYFATBOB
Exactly!!! When I use to drag race quads on dirt, the general rule was take 15 pounds off and you would gain a 10th of a second...
Hey, I've done my share of drag racing, @ the strip and on the street. 30# (about a tank of gas) off a 700# bike is less than 5%. And yes, you'd need a precision timing instrument to detect a difference in the 1/4-mile.
Quick Reply: weight loss/power weight ratio
