anyone can help with brake setup
RE: anyone can help with brake setup
Adjustable proportioning valves are available from any of the automotive speed merchants; Jegs, Summit, etc. Re-plumbing the brake lines and hiding one on the bike shouldn't be too difficult. The problem you are likely to have though is that the stock rear master cylinder won't have the volume to handle two calipers. Maybe you can find a much larger one.
l was thinking about replacing both masters with this: http://cncbrakes.com/cncbrakes.com-a...702&subseries=
and maybe get a large bore, shooter64 do you have a single master too? can you post a pic. please? thanks
