Hep me, hep me, I'm hypmotized
Old 02-22-2011, 09:29 PM
Dynamic's Avatar
Dynamic
Dynamic is offline
Default Hep me, hep me, I'm hypmotized
If you don't recognize that intro, it's stolen from David Letterman.
Dealing with a 2007 FXD with a brain fart. The security system seems to have decided that I'm not good enough to ride the beast. I turn the key, it gives me flashing tunsignals, left/right/left/right. The starter cranks, but no fire. I didn't hear the fuel pump kick in, either.
Changed the battery in BOTH of my fobs and no joy.
Stuck one right up to the left front turnsignal, then the other, then both. No joy.
Any ideas from the genius bar here?
Old 02-22-2011, 09:32 PM
Grind's Avatar
Grind
Grind is offline
Have you tried manually disarming security?
Old 02-23-2011, 04:50 AM
maddghost's Avatar
maddghost
maddghost is offline
It wouldn't turn if the alarm were activated.
Old 02-23-2011, 07:00 AM
bobnehoc's Avatar
bobnehoc
bobnehoc is offline
It is not the alarm system causing your problem. The bike would not even crank if it was the alarm. Since it cranks but you do not hear the fuel pump, check the fuses, check the fuel pump and wiring harness.
Old 02-23-2011, 11:05 AM
Silverearl's Avatar
Silverearl
Silverearl is offline
If the turn signals are flashing that is a warning and should be decoded. It is telling you the problem in code.
Old 02-23-2011, 03:09 PM
Zig Zag 2010's Avatar
Zig Zag 2010
Zig Zag 2010 is offline
Antonio 888
07-03-2019 04:50 PM
HarleyDoug
05-25-2017 08:45 PM
FLRoadKing
Electrical/Lighting/Alarm
04-30-2017 10:59 AM
Whitebrad25
04-15-2014 05:32 AM
tommarbru
12-28-2008 06:21 AM
Quick Reply: Hep me, hep me, I'm hypmotized
