Cleaning tarnish?
Old 02-17-2011, 06:41 PM
glideridemike's Avatar
glideridemike
glideridemike is offline
Originally Posted by DCLXVI
Metal polish should do it, I'm not sure what's in the chrome polish. What you are seeing is simply aluminum oxidation. You can only stop that by keeping oxygen away from bare aluminum. Since that is virtually impossible we are stuck with polishing.
I wonder if clear coating the aluminum would work. I clear coated my billet aluminum on an old classic car I had and it worked great.
Old 02-17-2011, 06:44 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,795 Likes on 2,537 Posts
You could use some Mothers Aluminum polish and then what I used after that was a product from Starbrite, Aluminum Polish , it's in a blue bottle. Gives real good protection and doesn't wear off as quick as other waxes. And it's made for aluminum boats. Good chit.
Old 02-17-2011, 06:57 PM
fiend138's Avatar
fiend138
fiend138 is offline
Not that it really matters but technically its not tarnish it oxidation
Old 02-17-2011, 06:58 PM
FXDLgrl's Avatar
FXDLgrl
FXDLgrl is offline
Originally Posted by Fridge
My rocker covers and yokes have gone like that, they are clear coated though aren't they?
I've not used any kind of abrasive polish for that reason, was just going to live with it until I swap them out for chrome.
For the rust on the chrome I would use a piece of fine wire wool.
Use both Mothers and Never Dull.
Prefer Mothers for aluminum.
Any protective coating was long gone on my aluminum before I got the bike. On aluminum i've used a dremel to buff some of the stubborn spots -being very careful to feather in and out to not leave a low area.
(someday I'll get a compressor and buffer and do it the right way)
Was going to get a new chrome triple, but got good shine on the aluminum although it is going to require maintenance.
Had been told to keep in mind that chrome gets cleaned while aluminum gets polished.
Had also been advised against using fine wire wool as it can leave tiny bits behind that are prone to rust.
True or not, I don't know...
Old 02-17-2011, 09:46 PM
maxxod's Avatar
maxxod
maxxod is offline
This stuff never fails, works great on oxidized boat parts that have been sitting in the salt air...
http://www.flitz.com/
Old 02-17-2011, 11:21 PM
jp-1's Avatar
jp-1
jp-1 is offline
+2 on the Happich simichrome, works friggin awesome on Aluminum.
Old 02-18-2011, 06:40 AM
TOMMAY's Avatar
TOMMAY
TOMMAY is offline
Use 0000 steel wool saturated with Mothers alum polish, follow with Semi-chome applied with a soft cloth. Will shine like chrome.
Old 02-18-2011, 06:58 AM
glideridemike
Bad thing I've seen is once the aluminum becomes oxidized, it comes back easier and faster causing you to have to keep up with it even more. Best this is to coat the aluminum well before putting her up for a long spell.
Old 02-18-2011, 08:55 AM
bobnehoc's Avatar
bobnehoc
bobnehoc is offline
Get a Mothers Powerball or Powercone and use a cordless drill. Choose what ever polish/cleaner you like and let the powerball/cone do the work.....Great time saver.
Old 02-21-2011, 06:04 PM
EastcoastFXD's Avatar
EastcoastFXD
EastcoastFXD is offline
Thx everyone for the suggestions, i had already used the simichrome without much success but the nevr-dull has helped alot, cleaned about 85% of the oxidation so i can live with he rest.
Quick Reply: Cleaning tarnish?
