Braided cables vs Stock cables.
![Post](https://www.hdforums.com/forum/images/icons/icon1.gif)
Braiding originally got started many yrs ago under NHRA rules to protect from fire and oil leaks. The way the rules used to read were any fluid hose longer than 6 inches OR running through or against other parts, must be braided. The braiding definitely protects from external abrasion and to some extent provides a support to the enclosed hose. But if abrasion (or looks) are not an issue, then good quality rubber hose is sufficient. When I buy rubber gas or oil hose I always buy the type that has internally woven fibers in the rubber. These are a lot stronger than rubber only lines.
![Smile](https://www.hdforums.com/forum/images/icons/icon7.gif)
Course at my age if I win the Lottery I would probably just buy a Heritage, which to me is just about the most beautiful motorcycle total package.
Braided brake lines definitely make a difference and until you try them you won't know. It is really simple hydraulics and if your line is swelling and stretching you are not transferring as much pressure to the piston in the caliper. I you believe they are just for looks then you have been misguided.
Your Fat Bob looks great! Love those pipes. I always was torn between the Street and the Fat Bobs. Course I ended up having to buy used so there where other factors of price and selection. But even though I love my Street Bob, I still think the Fat Bobs have more of the old Harley bob look.
I looked at your profile. You do a little drag racun do ya. Nice lookun Charger. Back in 1969 I had an Olds 442 Cutlass that I raced in E stock class at the strip. Had headers and 7inch cheater slicks. Turned high 13s and consistent low 14s. It would beat every Chevelle SS and GTO I raced but the Dodge GTX 440 magnum would take me in the traps every time. I could take the Dodges out of the lites but they would catch me. Cars were a lot heavier back then.
Again you've got a fantastic looking Bob. Later....R_W_B
Braided cables? Absolutely no benefit other than appearance.
Braided lines? Contrary to popular belief, there is no benefit in fighting swelling due to fluid pressure unless you're using substandard lines in the first place (which no OEM does). The brake lines (and clutch lines for bikes with a hydraulic clutch) already contain extremely strong fibers which accomplish this, often composed of kevlar.
So why braid hydraulic lines? Well, besides doing it for looks, the steel brading can protect the "rubber" line itself from nicks and cuts. On a motorcycle the line is more exposed than in a car. If the braiding were used for strength, then you'd see it as OEM on high performance cars like Corvettes and Ferraris (but you don't). The downside to the brading is that it hides any signs that the line is degrading due to age or exposure to the elements and chemicals.
Those who perform braided hydraulic line "upgrades" tend to upgrade other things (such as the line itself) and/or the pads, which is why they feel an improvement. There are also those who imagine an improvement which simply doesn't exist (such as those who claim that they felt an improvement after disconnecting the exhaust flapper valve in their Ducatis, not realizing that the flapper doesn't even operate when the bike is in gear).
YMMV
YMMV
