SE Fork Brace
SE Fork Brace
i am putting the se fork brace, part 46192-99A, on my 98 fxdl. a couple of questions. i have chrome lowers and it says not recommended in the instructions. all i can guess is that they dont want to be liable for scratches on the chrome as i can see no other difference between stock dimensions.
second question is, it is really togh to get these on. i will have to slightly nudge them into place with a rubber mallet. not too worried as it really is a nudge, but wondered if this is typical.
thx - tin
thx - tin
thx - tin
thx - tin
I installed the Super Brace model on my 05' FXDL and had the same problem as you. It was due to the chrome lowers as they are slightly thicker than the powder coated ones. The result was a slight gap in the pieces that bolt around the top of the lowers but I put a chrome washer in the gap and it is hardly noticeable. It bothered the **** out of me at first but now I don't even notice it. The people at Super Brace were great and offered to take them back but I kept them anyway. I think the fork brace along with the True-Track helped the way my bike handles. It better after $400+ for both of them.
I had the Custom Cycle Engineering fork brace on my 2000 FXDL and it fit perfectly on my chromed lower forks. Looks way better than the SE in my opinion. It's in mint condition (chrome) and fits a 39mm narrow glide front end. I removed it recently when I converted to a 49mm mid glide, so if you're interested in mine, send me a PM.
Here's a link to the CCE site so you can see what it looks like: http://www.ccesd.us/index.php?main_p...roducts_id=448
mine isnt about fork diameter, but the width between them...on so slightly.
tin
2010 FXDB
I'm big, 240 lbs, and ride aggressively. Am more used to bigger rockets and the way they handle, but will never go back.
Like twisting up the Street Bob as much as possible but don't have near the confidence in the front end, start getting a dead man's weave going if I hit a bump mid turn and am on it hard.
Any guys out there tighten this up with a fork brace? True-Track is spendy, $378 for an FXDB. Total I'm looking at $600 between the two?
Well, there's a long run for the forks from the lower triple tree to the axle, with a rotating joint half way along. This allows for some flexibilty, especially noticeable on wide forks.
A fork brace sits half way along the forks to add some bracing to reduce twisting and flexing.
Effects are that the front and may seem less skittish and squidgy (technical term ) on cornering.
LunaticFringe
10-17-2014 10:05 PM
4t8
09-20-2010 06:26 PM
