Sportster custom riser on FXD
Old 03-04-2012, 09:25 AM
DOUBLE-D-LOWRIDER's Avatar
DOUBLE-D-LOWRIDER
DOUBLE-D-LOWRIDER is offline
Default Thanks
Will any top clamp work with this, although i think i do want the idiot ligt set up..thanks agian...great help
Old 03-04-2012, 10:29 AM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
No ... you have to use the one (clamp) shown in either diagram above with the accompanying risers ... else the speedometer will not mount as shown ....
Old 03-05-2012, 09:14 PM
DOUBLE-D-LOWRIDER
One last question...will the stock cables work too...and a stock top clamp.
Thanks again for any help
Old 03-06-2012, 12:19 AM
SURFOR Chop
(1) your stock cables should have enough play in them to work with the Sportster riser setups pictured in this thread ...
(2) as for the top clamp, the answer is it depends on which setup you are going with ... if you go with the 2004-later then, NO ... the speedometer bracket is integrated into the top clamp; if you are going with the 2003-earlier setup, then it is a definite MAYBE ... the speedometer bracket is a separate part that fits (between the riser and / or above) the top clamp ... but, from the diagram, it almost appears as though the underside of the top clamp has a relief to accomodate the thickness of the speedometer bracket ...
CAVEAT ... I have no personal experience with either of these systems ... hopefully someone who does will chime in definitively ...
... study the photos a little better and the parts diagrams in post #7 ....
edit: after looking at the photos in post #2, it appears the 2003-earlier speedo bracket mounts atop the top clamp ...
Good luck
R/
'Chop
Old 03-06-2012, 07:41 AM
DOUBLE-D-LOWRIDER
Thanks again..i have a chance to buy the risers used at a fairly good deal $50...si i think i'll get it and try to find the clamp with just the idiot lights..so i can get of the light brow and relocate my head light..thanks much
Chris Stockwell
05-13-2019 09:14 AM
roundy
12-05-2012 03:37 AM
Bonkerz
10-28-2009 05:38 PM
Rgonot
09-08-2009 10:14 PM
jasenr
11-03-2007 01:07 PM
Quick Reply: Sportster custom riser on FXD
