Need some Help finding Parts (Handle bar change)
I have changed risers from the stock 4" to short 1 1/2'~2" chrome risers. I installed Fat-Boy pull back style handle bars, I happened to have some throttle cables the right length to work and look good. I believe I have the right clutch cable (from a friend) to install to night.
What I am having some problems with is finding some hydraulic lines or parts (to build my own) to replace the stock brake lines.............
I have two sets, the original which the lower part is right, but now the top line needs to be 2~4" longer. And a set up from a touring bike, but needs a lot of modification.
Is there any inline splice compression fittings available for stock lines?
or
Any suggested web page to find the parts to build my own at a reasonable price?
Any and all suggestions welcome.......
By the way the bike is really starting to look like an Old Skool "Bobbed" Bobber.
The bike does not even look close to the picture below (that will be up graded as soon as I get the brakes straightened out)
As soon as the handle bar modification is done then I finish with the Fishtail extensions on the pipes
Thank'z All
or
Thank'z All
Try this site for making your own brake lines.....http://www.magnumshielding.com/
Thanks I'll check them out.............
Anybody else with suggestions?
HD Modular Lines - you order the dual lower section and then pick out what length you need for the upper.
