Ricor shocks for Lowering Dyna Low
I've read alot about Ricor shocks, I have 11' progressive shocks on my bike now and it has made the ride extremely rough and corning at a higher speed I get like a stepping out feeling. I need the bike lower because of my height
Has anyone used these shocks to lower the seat height and has it made the ride really hard ???
thanks
JoyRyd
thanks
JoyRyd
thanks
JoyRyd
thanks
JoyRyd
![Lightbulb](https://www.hdforums.com/forum/images/icons/icon3.gif)
thanks
JoyRyd
thanks
JoyRyd
If you don't have a pair consider getting some. You only 'need' help when stopping or stationary. You need decent suspension all the time you are moving. Don't spoil the ride any more than absolutely essential!
If boots solve the problem, consider high quality custom shocks to improve your ride. Get custom Ohlins from HDF sponsor Motorcycle Metal.
![Wink](https://www.hdforums.com/forum/images/smilies/wink.gif)
I believe the shocks are actually the HD ones, I'm certainly not that heavy but when I ordered them from Harley, that's the ones they got me. I have them set to the lowest setting, I will try adjusting them to the middle and see if that help.
As for the footwear, I do wear proper riding boots and usually have a bit of a heel on them, right now the height is perfect and my boots are fine, it's just the stiffness of the ride I'm not happy with.
![Wink](https://www.hdforums.com/forum/images/icons/icon12.gif)
I would agree, be careful on your suspension performance,you will eventually need that suspension to keep you upright in a dangerous situation. Give Howard a call and talk through your situation with him..
One solution to consider is getting custom shocks built. HDF sponsor Motorcycle Metal will build you a wonderful set of Ohlins matched to your weight and riding style. I have a pair on my Glide and they are the first shocks I have owned in over 30 years of Harley ownership that do not bottom out when my wife and I are riding together. If Howard can do it for us I reckon he can do it for you too! Give him a call.
I had those shocks for a couple of years and was never completely comfortable with them.I played with the preload allot and found the middle position to be the best.Also I found the bottom or softest setting caused some handling problems.With 11" shocks you only have about 3/4" of travel so I don't think going to a more expensive shock the same size will help you.If you're lowering because you're hieght challenged a custom seat and or boots with some extra lift in them should be your first two steps.Also remember you only have to be able to touch the ground with one foot at a time, otherwise your bike would need two kickstands.
I would verify if the shocks are Heavy Duty and if they are and you are not 200lbs the dealer ordered the wrong shock for you and you need to take them back and get the STD or your money back. I think progressive will swap out the springs for you if you send them the shocks. If you have the HD version increasing the preload does not sound like it will help. With the 11" you are most likely going to bottom out no matter what, but you need to find out if it is bottoming out or too much spring rate so you base line the problem.
Granted there are better shocks and Ricor is one of them and at a competitive price. Ricor does make an 11" according to their website so call Ricor and ask for their opinion. There is a huge cost difference going from a 412 to a really good shock so you have to consider what is in your budget too.
Definitely should try to stay with a 12" and you could try using lowering blocks, but you have to make sure you won't bottom out on any hard parts.
+1 on the lower seat and you can also lower the front some to lower the ride height a little and putting a little more weight back on the front will also help, lowering the rear and not the front an equal amount will transfer more weight to the rear, the suspension is dynamic and works in tandum. You could lower the fork tubes in the triple trees about and 1" so that is a simple test to see if it helps.
CB
Thank you all for the advise, I will give Howard at Motorcycle Metal a call and see what he says.
As for the boots and seat, I've got that covered, boots are high and seat is carved out.
As for the front forks, I have lowered them as well 1" when I put the 11" shocks on. I will try and set the shocks in the middle but I do think that Harley ordered the wrong shocks as I'm not even close to 200lbs.
thank you all for the advise.
slim_powers
10-13-2015 09:19 AM
