Pinch Bolt Turn Signal Mounts
I want to use this style mount for the front signals - http://www.jpcycles.com/product/320-209
J & P says this will only fit V-Rods. Does anyone know if this will fit an '09 Dyna? If not, where can I get this style for a Dyna?
I'm not sure if there the exact same as the ones I got, but the ones I got do work. The ones I got are from drag specialties. They look just the same. The ones I got were just a c hair too big. I had to run they once around the bench grinder and the fit perfect. It looks good when it's done too.
They are very easy to make. All it takes is some 3/4" x 1/8" flat bar bent into a 'Z' with holes drilled in each end. I also made a set out of two straight 2" pieces of aluminum FB, drilled the holes, then cut 2 pieces of chrome 5/8" round tube to about 1" long to use as the stand-off. A bolt about 2" long running through the FB and tube into your light's mounting hole will secure the light. The other end bolts on with the cinch bolt.
