What hp/tq numbers should i expect?
Old 01-18-2011, 04:28 PM
formike56's Avatar
formike56
formike56 is offline
SE 255 are good cam's. Along with the heavy breather. It will bring your #'s up to a respectable area.
Old 01-18-2011, 04:34 PM
kk6pg's Avatar
kk6pg
kk6pg is offline
Chris, dont waste your money on a dyno just yet. Just download a map for a configuration similar to yours and run the bike. Unless the map is AFU, you wont kill the bike. Wait until you have made significant changes to the motor before you dyno.
When you do dyno, leave the bike in your normal riding setup. You'll be happier in the long run. No need to run 5w20 synthetics in the motor or trans, or loosening the axle nut a half turn, or loosening the drive belt a smidgeon just to raise the numbers. You want real world numbers, not fantasyland.
Old 01-18-2011, 04:40 PM
07bobber's Avatar
07bobber
07bobber is offline
Originally Posted by kk6pg
chris, dont waste your money on a dyno just yet. Just download a map for a configuration similar to yours and run the bike. Unless the map is afu, you wont kill the bike. wait until you have made significant changes to the motor before you dyno.
when you do dyno, leave the bike in your normal riding setup. You'll be happier in the long run. No need to run 5w20 synthetics in the motor or trans, or loosening the axle nut a half turn, or loosening the drive belt a smidgeon just to raise the numbers. You want real world numbers, not fantasyland.
larry-i was thinking i should wait til i get cams anyways...
Good idea with the loose axle nut haha
Old 01-18-2011, 05:03 PM
kk6pg's Avatar
kk6pg
kk6pg is offline
I wish I could have went on the ride you made with the Nomads a couple of weeks ago so I could have a better idea of how you ride. At least then I can make a better decision as to what cam you really need. I will say this, unless all you plan on doing is screaming up Ortega to Hells Kitchen and back, lets put the 555 on a back burner.
Old 01-18-2011, 05:24 PM
07bobber's Avatar
07bobber
07bobber is offline
Larry- i was wondering where you were hiding that day.
I think i want more of a low to mid range cam to be honest more than half of my riding is backroads and the other is highway. I normally ride the speed limit not really into the hot shot take offs or going over 85 (rarely) if im rushing on the highway...i need something to pull my big *** and my wifes butt up hills when she rides with me...
Old 01-18-2011, 08:25 PM
Karsten's Avatar
Karsten
Karsten is offline
I wanta play
So you are setting a 96 inch with a pipe and A/C at 72-74 HP
How about a question as to an 06 SB
88 to 95 Inch conversion
10.25 to 1 SE Pistons
Fueling Reaper 575 lift cams
Roller race lifters
Ported, polished flow tested heads with 1.90 intake and 1.63 exhaust
SE High Flow A/C
Stock head pipes, empty Rush slip ons with Big City Thunder baffles in the head pipes
SE Super Tuner set to the break in program until I get 1000 miles in it and take it back to be dyno'ed
What is your estimate of HP and TQ
Karsten
Old 01-18-2011, 08:55 PM
paul s's Avatar
paul s
paul s is offline
Originally Posted by Karsten
I wanta play
Roller race lifters
Ported, polished flow tested heads with 1.90 intake and 1.80 exhaust
SE High Flow A/C
Karsten
A 1.80 exhaust valve? That seems kinda large.
Old 01-18-2011, 09:00 PM
bigdady's Avatar
bigdady
bigdady is offline
I sure love the 211's i put in my 08. just did the dyno tune last Saturday with nice #s 96hp 106 lb tq
Old 01-18-2011, 09:15 PM
Karsten's Avatar
Karsten
Karsten is offline
Whoops, my bad 1.63 Exhaust something else was 1.80 or hell....I just have to many numbers rollin around.
Karsten
Old 01-18-2011, 09:52 PM
coolerman69's Avatar
coolerman69
coolerman69 is offline
I wanta play
Roller race lifters
SE High Flow A/C
Karsten
Sounds a lot like my build. I have se257 race cams. 104hp 106tq
Quick Reply: What hp/tq numbers should i expect?
