What sort of pre-ride inspection is part of your routine?
T-Dub. I'm surprised you can get yours out. Maybe I have my heat shields on a little differently. When I put them on I thought maybe I missed something in the instructions. I called Vance and Hines and they said that all of their pipes fit tight with not much clearance but with the Big Radius there is none. I tried one of the LCD dipsticks but the stupid piece of junk fried from being so close to the pipe after maybe a month or so.
Fatbob, I have the same pipes. Even though I have a SB the setup should be the same and I don't have a problem either... it is a bit tight and I have to wear gloves when the bike is hot so as not to get burned, but it comes out without any problems... hmmmm
Oh my pre-ride check... well since I ride it every day I don't do much but check it out when walking up to it, feel how it responds as I sit on it and how it feels when I back it out of the garage. Then, just head out. Check the oil before any long ride and any time I really think about it. That's about it...
My once a week pre-ride:
1. engine oil
2. tire pressure & quick visual on tread
3. visual on the drive belt
4. look under bike for leaks
5. lights, turn signals.
My once a month check:
1. the once a week check
2. go over bike with a wrench
3. trans oil check
4. tire tread inspection (close)
Annual end of season:
1. oil service (all 3)
2. drive belt tension
3. bleed brakes
4. critical fasteners
5. lube cables
6. inspect battery
7. inspect RR air filter
8. clean TB
9. new spark plugs
10. winterize
1. engine oil
3. trans oil check
3. bleed brakes
5. lube cables
6. inspect battery
8. clean TB
9. new spark plugs
10. winterize
