Need Help with Dead Speedometer
I have a 2002 FXDL and the speedometer isn't working. The back light is working, & the odometer reads 11K miles. When the key is turned "on" the needle goes all the way down (to zero) and then bounces up a little bit (as if it just calculated itself). When I drive there is no movement at all. Thanks for any help in advance.
Received 4,857 Likes
