Bike dead after sitting outside all day
Rode my bike into work today, at quitting time I gear up and get on the bike, the damn thing wont start. It turns over slowly but not enough juice to kick it over.
It was about 30 degrees when I rode it in this morning and was in the 40's all day.
I had my wife bring my trickle charger and I charged it for a couple of hours and it turned over and I was able to ride it home.
I checked battery connections when I got home and both terminals were snug but not overly tight, so I tightened them and spray some terminal protector and hope this problem is behind me.
I use a trickle charge, as the battery drained once before when I let it sit for a week.
If it happens again, what should I look for ?
The bike is an 04 SuperGlide, and the battery is less than a year old.
Yeah, sure sounds like your battery is toast. They can be real tricky, OK one minute and crapped out the next.
It'll cost you ~$150.00 or so but my advice is to buy a new Harley branded battery and your choice of a Deltran brand Battery Tender and be done with it for another 4-5 years.
Life's too short to have to worry about your battery and this will do the trick.
If you have a digital voltmeter and a fully charged battery you can pretty much determine if you have a bad battery. This should help you.
http://www.ehow.com/video_2330193_ch...e-battery.html
