Whats better for wiring handlebars?
i was lucky my wideglide had enough wires already in the frame for 16" Bars
Nams sell wire extensions, easy kit to use all the hard work is done !
http://www.namzcustomcycleproducts.c..._96_to_06.html
I also acquired some braided nylon wire loom (as well as some stainless braid) to cover the wires coming out of the bars and down to the backbone. I wasn't sure if I wanted the stainless (to match my cables/brake lines) or not. Turns out the black nylon braid looked better.
Everytime you make a connection you create a chance for failure. There is less a chance if you use plug assy's and they are put together correctly. Everytime you use solder you put more resistance in the wire run. Maybe its negligible maybe not. But its there. I have also seen solder joints gather moisture over time. No shrink tube is going to keep 100% of the moisture out. Doing it more than once helps, but in all my years of building cars and working on bikes I have found sticking to conventional terminal block assy's to be much more reliable, and breaking down on the road with shorted wires in your bars is a whole lot more of a b!tch than when in a car, so I go with what I have found to work the best for me. My bud also agrees and he's been a HD wrench, service mgr and bike builder for nearly as long. So its not just me.
So I guess we'll just have to agree to disagree. I sure cannot question your work or creations JRK, you make some wicked cool bikes.
As many times as this Joe changes bars I would have to agree with him. Many issues to be had with those extensions. Everybody I know who is experienced in HD building solders the connections. They do make rolls of wire that have all of the HD colors in them. The best of both worlds. Solder and color matched. I am cheap so I will just get some 16-18 ga and take my time wiring and marking the wires.
