Chrome Lower Forks
The first time I swapped lowers/disassembled the forks, I sat and read that section of manual and found nothing in there to be of any use.
The 12mm hex you would want is available at NAPA. It's the perfect size to reach up into the forks to loosen the damper rod bolt.
Napa p/n: NPT 615312
http://www.napaonline.com/Search/Det...312_0006572290
Fork seal driver:
http://www.youtube.com/watch?v=41nQpVA8um0
Get some masking tape, and some scotch brite, coarse and fine. pull the wheel and fender and mask the rubber then scotch with the coarse till the clear is gone. now use the fine to smoothe things up more, then get a towel and some Happich Semichrome at your dealer. use sparingly and polish the tubes. If it is turning black it is working. shine it up and use a coat of wax to keep it good till you polish it again. each time you polish it, it will get shinier. terrycloth towel is the rag ticket
Just did mine and turned out great. Some key areas of concern are to ensure that you don't strip out the hex screws at the bottom of each leg. Helps to loosen up the hex screw and tube cap before taking off the bike if possible. You'll need a work table or vice of some kind to hold the legs straight up while you work on them, especially when replacing the seals and putting the caps back on. PVC piping works great to seat the primary seal down, although I was afraid that I was going to damage the rubber seal with the edges of the pipe, but never did. I also replaced the pinch bolts and hex screws with new hardware. Make sure you have the right tools as well. Mine took a 35mm socket for the caps and a 6mm extended allen for the hex screws.
Fix Your Hog has a really great video for helping you visualize what you need to do for a step by step. May not be exactly the same fork that you are working with, but its all the same and easy to relate. Best $20 I spent and things went really smooth...except for stripping the hex screw in one leg, but that's another story..
