06 night train wheel on 07 street bob, has this been done?
??? is this the front or rear your talking about? The front night train wheel will take more than spacers to make work on an 07 bob. The rear is setup with 3/4 axle and the bob has one inch. The night train hub would need to be bored out to fit one inch bearings or you need to make a 3/4 axle fit your bob.
I do believe you will need more than spacers. The 06 NT should have 3/4" bearings and your 07 SB should have 1" bearings and it is not as simple as just changing bearings.
this is on rear 17x6 nt wheel. put new 1in bearings so i can use 1in axle had to by an 08 inner sleeve and cut to fit between bearings. just need to know which spacer should be cut. tnx for the inputs guys.
Posted this on another thread too but this one would have been better since you started the thread. Here is the link to the write up I did on the install of a 06 NT wheel. I used the stock spacer on the brake side and made one for the pulley side at 1.935" in length. I am unaware of rear swingarm/fork spread differences from 06 and newer dynas so should get you in the ballpark.
Here is the thread https://www.hdforums.com/forum/dyna-...-on-06-wg.html . No pictures but has typed info. Pictures I believe have been deleted from my album to make room for others sorry.
