Dyna Vibration problem
Old 11-28-2010 | 10:41 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I would check your engine mounts and tire balance.
Old 11-28-2010 | 12:18 PM
GPHDXLC's Avatar
GPHDXLC
Originally Posted by J. Klarich
Have them check the crank run out just because
From what I been through with 3 different Dealers with my motor vibration problem, they wont check the crank run out under Warranty. HD now has such a high crank run out number no matter how bad it vibes it wont get to that number to get it fixed under Warranty. I have been fighting for a crank run out check all Summer but I will have to pay for it, and that's not going to happen... Good luck.
Old 11-29-2010 | 09:17 AM
hell hound's Avatar
hell hound
if it was the crank it would do it in all gears
Old 11-29-2010 | 09:24 AM
hell hound's Avatar
hell hound
do you have a tach?
does it do it at certain speed or certain rpm?
do you feel it mostly in feet or hands or butt or everywhere?
can you see clearly out of mirrors at highway speed?
is it worst immidiatly after you shift or right before you shift to next gear?
what speeds are you shifting?
Old 11-29-2010 | 11:13 AM
KBFXDLI's Avatar
KBFXDLI
+1 crank runout does not come and go at certain engine speed.
Old 11-29-2010 | 03:59 PM
GPHDXLC's Avatar
GPHDXLC
Yes that's a good point, mine has a very harsh vibration with the rpm and it dose it in all 6 gears. Yours must have something to do with the gears them self's, or how about the compensator? Hope you van get your vibe problem worked out...Good luck.
Old 04-07-2017 | 02:27 AM
Ron Won's Avatar
Ron Won
Stage III
2010 dyna with the same problem and i no this much its not tire balancing and im fearing the worst my bike just hit seven thousand miles and it feels like crank balancing or main shaft bent it defiantly a factory defect ive been riding harleys my whole life and its internal the vibration gets worse and ive change both isolators and no differance shim the front one same thing havent taken to the dealer but if they tell me keep at the speed limit ill drive it through the front window and buy a vespa
Old 04-07-2017 | 05:06 AM
Smogbob's Avatar
Smogbob
If tyres are stock from 2009 and you have only 5k on them could be a little flat spot on a tyre due to storage over long lengths of time, just an opinion.
Old 04-07-2017 | 06:18 AM
blackxpress's Avatar
blackxpress
Just curious. Have you ridden other Dynas besides that one to be sure the problem is limited to your particular bike? I ask because I rode a new Dyna Fat Bob the other day and couldn't believe the amount of vibration after being used to my Road Glide. It felt nice and smooth at 70 mph on the Interstate but I couldn't see in the mirrors and if I varied the rpm at all I could feel it in my hands and feet. Around town, at certain rpm it was like riding a washing machine. Nothing wrong with the bike. Just the nature of the beast.
Old 04-07-2017 | 06:21 AM
br549A1's Avatar
br549A1
I'll narrow this down for you but you have to listen.
1. It's not the crank if it was you'd be complaining about 1-2-3 acceleration as that's where you're in the highest RPMs.
2. You're in too low of a gear for the speed you're at in 4-5-6. If you downshifted and held it higher it will smooth out.
3. Sit still in you're driveway on neutral with the bike warmed up and idling. Slowly increase the RPMs slowly giving it throttle. You'll feel that vibration you're complaining about come on strong then fade as you pass it in the RPMs. Listen to the engine and when you're riding you'll learn to avoid it and downshift before you're that low.
4. You don't have a tach on that bike, I'm willing to bet that it's in the 1900-2100 range. If you have access to a digital tach you can verify it. If you avoid this range you'll be fine. Most Dyna riders cruise at much higher RPMs.
5. Go ride and avoid that RPM for cruising and you'll be fine.
Jackpoticorn
07-07-2016 06:29 PM
Nigel Shutt
07-21-2014 07:37 PM
dmercy
General Topics/Tech Tips
09-19-2010 09:22 AM
flight
05-26-2010 11:18 PM
KSGLIDEGUY
07-07-2008 08:27 PM
Quick Reply: Dyna Vibration problem
