Hinged Shovel fender install, w/ pics.
Old 11-29-2010, 08:08 AM
SURFOR Chop's Avatar
SURFOR Chop
SURFOR Chop is offline
Looks good Neil ...
Yesterday was a pretty day; but, it got really chilly after the sun went down ....
I rode back to the Tidewater from DC yesterday afternoon ... I-95 South was a parking lot ... I got off at Fredericksburg and took 17 from there ... (it was 29* when I passed through Tappahannock) ....
How are you securing the rear part (aft of the hinge) ...? Do you have a strap bolting it to the strut on the inside ...?
Work on mine is progressing ... I must be using a different fender, because I need some spacers to take up the gap between the struts and the fender ... I am making them to 'elongate' the strut to reach the rear mounting hole, aft of the hinge ....
I'll start a thread to show what I've done in a couple of days ....
R/
'Chop
p.s. did the front of your fender require any cutting or shaping to clear the swingarm and fit properly ...?
  #32
Old 11-29-2010, 09:37 AM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
R/
'Chop
OK, first question, yes there was a bit of a gap but I just laid the fender on the bench and stretched it out a tad. Just used my hands per say. Kind of grabbed and pulled the sides apart. Then when I added my sissy bar last night, the mounts took up even more of the gap. Yes, spacers would have been nice, but I wanted as much room under the fender as possible to avoid any clearance issue. I ride two up most of the time and I don't want that fender or anything hanging underneath it (like the wiring harness) to come anywhere near the spinning tire. Remember, the fender is just a piece of stamped sheet metal. There's no reason to fit the motorcycle to the fender, fit the fender to the motorcycle.
The second thing you mentioned was locking the hinged rear section down. At least with this particular rear fender, I did not have that concern. From the factory there are two fairly stout steel brackets welded to the inside of the front section of the fender. They extend back threw the rear section, and a bolt threw each side of the rear section bolts that rear section to the bracket. Those bolts, in addition the the riveted hinge itself and the 4 additional welded alignment tabs (that Shovels used from the factory) hold the rear section extremely tight. Believe me, before I had this monster in my possession, I was already assuming it was a pile of lightweight dog-poop like the debrix fender was. I had already visited my local welder about handing it over to him to weld up supporting brackets, but when it got here I was shocked how heavy, thick and strong the fender was. If you notice in my pictures, the bolt between the rear tip of the strut and the turn signal is that bolt. It a little too noticeable right now because in my haste to finish I used bright white nylon washers between the bolts and the fender to protect the paint from chipping. I will switch those nylon washers to black sooner or later, but at the time all I had was the white ones.
Also, let me offer you one tip since you mentioned extending your strut by means of a bracket to secure the hinged section. Make sure you check clearance for accessories such as sissy bars and passenger seats. Because at least on my fender, had I tried to use the Shovelhead hole pattern that came pre drilled, the fender would have sat so high the sissy bar brackets would never have fit, and would have been in total contact the fender. Using that hole pattern would have meant not being able to install the sissy bar and I would have lost my backrest and luggage rack. So check that fender with every single accessory you "may" want to use one day down the road, even if you don't use it now, because once its on and painted, its too late! If you look closely at where my bright white rear section lock down bolt actually is, you can really see how much farther I had to slide the fender down in the struts than where the factory Shovelhead holes would have put it.
Lastly.....geeez I'm rambling.....Yes, I did have to trim the fender. When I first bolted it to the bike it didn't appear as if I was going to need to do that, but once I really got it to where I liked it I wound up cutting about two inches off the front tip and over the belt guard. I just free handed it with a sharpie pen and cut it with a jigsaw, then smoothed the cut with a 5 inch grinder. Not very much trouble or work at all. I hope all this rambling is a little helpful.
Neil
  #33
Old 11-29-2010, 12:13 PM
07bobber's Avatar
07bobber
07bobber is offline
Way better fender this time around !!
  #34
Old 11-29-2010, 03:57 PM
09DynaRyder's Avatar
09DynaRyder
09DynaRyder is offline
I like it!
  #35
Old 11-29-2010, 09:15 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
Phew! I put the seat, bags, sissy bar, pad, brackets and luggage rack on. Now the fender sits exactly how I hoped it would. I was a tad worried about sitting too high in the rear, but I think now that its all finished its sitting where it ought to. I would have put the lowering blocks back on, but I'd rather not run them unless theres a true need for them. Thanks for all the props and comments along the way. Now, all the wife and myself need is a few sunny weekends to enjoy the old girl. She's done for a while....thats for sure.
  #36
Old 12-02-2010, 09:16 PM
SURFOR Chop
An update with a few photos ...
The first three show the cut-off to the front edge of the fender ... my cut to the belt guard side did not take enough ... I hadn't looked at the stock fender ... the cutout needs to extend all the way around the side ....
These two photos show where the fender contacted the frame downtubes ... so, I needed to flatten the spot down the way the stock fender is ....
  #37
Old 12-02-2010, 09:35 PM
SURFOR Chop
After making the flat spot on the front of the fender, I was able to get it to fit ... a couple of shots of the fender in place ....
This one shows the clearance issue with the belt guard ... I'll need to rework this part of the fender ....
One from the rear ....
Attached Thumbnails Hinged Shovel fender install, w/ pics.-dscn1276.jpg   Hinged Shovel fender install, w/ pics.-dscn1277.jpg   Hinged Shovel fender install, w/ pics.-dscn1278.jpg   Hinged Shovel fender install, w/ pics.-dscn1279.jpg
  #38
Old 12-02-2010, 09:52 PM
SURFOR Chop
Put my seat in place ... fits about the same as with my stock fender ...
A little gap ... but, once I get the fasteners worked out, should pull it up snug ... I think I am going to use studs with stainless steel or chrome acorn nuts ....
bikerlaw advised checking clearance with any accessory I plan on using ... this is my QD rack/back rest on the stock fender ... there appears to be enough space to clear the new fender ... I'll try it on the fender when I work on it tomorrow ... I need to mark it up for holes for the seat nut, tombstone tail lamp and turn signal bar ... I think that's all I'll do for now ... the license plate mounts on the top of the tombstone ...
So far, turning out about how I was hoping ....
Attached Thumbnails Hinged Shovel fender install, w/ pics.-dscn1280.jpg   Hinged Shovel fender install, w/ pics.-dscn1281.jpg   Hinged Shovel fender install, w/ pics.-dscn1282.jpg   Hinged Shovel fender install, w/ pics.-dscn1283.jpg
  #39
Old 12-02-2010, 11:00 PM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
OMG! Thats freaking kick a$$! Excelent design.
  #40
Old 12-03-2010, 08:28 AM
SURFOR Chop
Thanks Neil ... hope to finish up this evening and get it ready to send off to PowderPro ....
R/
'Chop
Quick Reply: Hinged Shovel fender install, w/ pics.
