2007 FXD Low Rider - Kickstand Placement
Old 11-23-2010, 06:24 AM
Octavus's Avatar
Octavus
Octavus is offline
Default 2007 FXD Low Rider - Kickstand Placement
Getting the kick stand out, requires my left foot to be a contortionist yoga master, while trying not to burn my ankle boot. Any ideas on making getting access to it easier? Is it adjustable?
-Oct
Old 11-23-2010, 06:27 AM
redrubicon2004's Avatar
redrubicon2004
redrubicon2004 is offline
How long have you had the bike? It doesnt take long before its second nature.
Old 11-23-2010, 06:32 AM
Octavus's Avatar
Octavus
Octavus is offline
About a month. Should probably add I'm a bit short at 5'7".
Old 11-23-2010, 08:15 AM
goblin127's Avatar
goblin127
goblin127 is offline
I can usually get mine out first attempt with right side of heal. I'm 6ft1
Old 11-23-2010, 08:24 AM
bobnehoc's Avatar
bobnehoc
bobnehoc is offline
I Have an 07 Low Rider also and I do not have any issues with the kickstand and I am 5'4". You can by an extension that clips/bolts on to the end of the kickstand that is supposed to make it easier to use. Check JP Cycles I believe they carry it. I think after a little while it should just be second nature to use the kickstand. I will tell you what I do have trouble using is the horn. I wo rarelly use it that when I need to I can't seem to find the button quick enough, so I just usually yell at the A Hole instead.....lol
Old 11-23-2010, 10:12 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
-Oct
You aren't going to burn your ankle on the primary if you are wearing MC boots. Just hook the end tab on the jiffy with your heel and move it forward. I am 5' 11" and it is second nature. Stop. Hold the bike with your right foot, point your left foot a little to the left and swing your heel under the backside curve of the primary and your heel will hook the jiffy every time.
Old 11-23-2010, 10:27 AM
Jarhead08's Avatar
Jarhead08
Jarhead08 is offline
You can always just prop the scoot against a car or pole! Lol
Old 11-23-2010, 07:49 PM
Octavus's Avatar
Octavus
Octavus is offline
Replies appreciated. Guess it's just getting used to it, just seems like bad design. Another 1/2 of a lip and it would be easy to flip with your toe.
Old 11-23-2010, 08:22 PM
ackman1968's Avatar
ackman1968
ackman1968 is offline
If you are using your toe it will be a fight, use your heel as mentioned earlier and it will be as easy as hitting the floor when you fall.
Old 11-23-2010, 11:40 PM
AZFXDB's Avatar
AZFXDB
AZFXDB is offline
Is this thread for real?? Who needs instructions on using a kickstand? That **** is built into your DNA
Quick Reply: 2007 FXD Low Rider - Kickstand Placement
