FLH forks & nacelle on a Dyna?
One of my riding buddy's has a 1997 Dyna Convertible. I was talking up all the guys doing the FLH style conversions on this forum and now he's interested. First thing he wants to know is the fork thing. What information can I give him about a set of 41mm forks that will both fit the Dyna neck as well as be drilled and tapped for the nacelle. My first thoughts were to tell him to buy an old Shovelhead set of FLH triple trees and just build it up from there. But I don't know if they will fit on the Dyna neck. Will they??? What else will fit and still have turning radius. I know I had a heck of a time fitting a Springer and getting turning radius! Is that even an issue with the hydraulic forks or is it a non issue? Please give me some info to pass on to the guy. He's pretty interested in getting a tinned up set of forks on his Dyna.
Ackman1968 had the nacelle and removed it after a while ... it limited the adjustment of his headlight and he ended up reverting to the tins/shrouds ....
I did a write up on mine (think it is titled "began dismantling my narrow glide" or some such) ... also started a social group ... I've posted several links to a great website by a guy named Ken whose write up I used for mine ....
The nacelle might work on a Wide Glide which has a little more rake, but the rest of the Dyna lineup has 28* rake and that's not enough to use the nacelle ....
R/
'Chop
R/
'Chop
Chop, I joined the section a while ago and was gonna post this up there but forgot. I was hoping Shovel trees might be the answer because they have negative rake from the factory. They are not zero or neutral like many trees and that sounded like a plus, but I don't know about turning radius. I'll check your writeup for sure.
Traveler, will fatboy trees bolt on a Dyna? If so that would be his answer. Get a stripped Fatboy front end and buy that aftermarket nacelle conversion....no?
I believe "Surfor" has fatboy forks. Same with "Ackman 68" I think that is his name on here.
I know Rick Doss makes an aftermarket nacelle available through Custom Chrome. That nacelle MIGHT fit on a standard wideglide tree arrangement, but not sure.
I am from the school of "modify to make it work"....so that means to me...buy the stuff and do what's necessary to make it fit and work.
P.S. Why are you selling your bike?
~joe
~joe
