Bagger fender setup for a wideglide forks
#33
No probs with the fender. Perfect fit. When I started the FL-Dyna build I had plans for a Heritage fender but I got sidetracked by the taller/narrower front tire look that is getting popular with the FL people. My local bike/machine shop had a disk spacer that required very little machine work to make the disk line up with the caliper. The shop also made the axle/wheel spacers. I didn't like the look so I went with my orignal plans.
To get the 19 wheel to fit correctly a custom axle would need to be found or made. Axles have raised areas for the wheel bearings to ride on. Harley does not put a 19" wheel on a wide front.
Fabbing a DYNA is what is required when doing an FLH conversion!
~Joe
#34
