Keeping aluminum parts clean
also be careful using chemicals to clean your alunimun. I sprayed some Superclean on my motor to clean some road grime and oil off and it ruined its brightness. turned the non polished alunimun parts dark gray and the polished parts was dulled also.I tried some Aluminum Brightner thats for aluminum and it did nothing but brighten the dullness of the wheel rims. It seems to only work on polished surfaces ?
ZoopSeal™ Protective Sealer http://zoopseal.com/
Protect all your polished aluminum, stainless steel and chrome parts from oxidation and eliminate the need for repeat polishing. Each deluxe kit covers 75 square feet. Easy to apply when following the instructions provided. Formulated for use on cars, trucks, boats motorcycles, engines, wheels and interior accessories.
New improved formula offers unsurpassed protection
and is more user friendly
When applied properly ZoopSeal™ will:
- Prevent dulling and oxidation
- Retain the polished brightness and luster of aluminum
- Eliminate the need for repeat polishing
- Be long lasting
- Will work on aluminum, brass, and stainless steel
- Be safe to use and environmentally friendly
- Eliminate undesirable powder coating or chrome to chip, peel, and yellow
NewHarleyGear
Support for The Troops and their Families
11
03-07-2011 10:17 AM
