drive belt question
Old 11-11-2010 | 09:43 PM
ccnova's Avatar
ccnova
Default drive belt question
Just found this on my 98 Dyna. Should I leave it alone or try to get it out? Or do I need to get a new belt?
http://i288.photobucket.com/albums/l...NTIuanBn-1.jpg
Thanks for the help,
ccnova
Old 11-11-2010 | 09:54 PM
redrubicon2004's Avatar
redrubicon2004
What exactly is it?
I would run it, check it often and watch for possible failure.
Streetbob Bomber's Avatar
Streetbob Bomber
Cant really tell in the pic what it is, but if there is something stuck in your belt it is likely that it is also doing harm to your pulleys as well, so i would give them a look too!! JMO if the belt has any significant damage change it or it will leave you on the side of the road, "wouldnt ride on a bike with a chain with a cracked or damaged links or teeth missing on the sprokets either"
Old 11-11-2010 | 10:12 PM
bigdaddy33's Avatar
bigdaddy33
If the belt on the '98 is the same size used on the '00, you can have the belt I took off years ago when I switched to a chain. If you're interested let me know. I think it is in mint condition.
ccnova
Old 11-11-2010 | 10:13 PM
ccnova's Avatar
ccnova
Not sure what it is. I have checked the rear sprocket and cant see any damage. What ever it is it is completely embedded in the belt. I cant see any thing sticking out on the inside of the belt. I asked a couple people around here what to do and one said leave it alone and keep checking it. The other said dig it out and keep checking it. What do you guys think?
Old 11-11-2010 | 10:26 PM
ccnova's Avatar
ccnova
Wow thanks for the offer! I appreciate it. Not sure if it will work or not. This is my first Harley and I love it! This is also the first problem I have had. Riding weather is gone around here now so I do have some time to deal with it. Heres a picture of the bike also.
http://i288.photobucket.com/albums/l...A2NDIuanBn.jpg
Old 11-11-2010 | 11:38 PM
lo-rider's Avatar
lo-rider
Default X belt
Recommend replacing belt. Nice bike; take care of it.
Old 11-12-2010 | 01:13 AM
parts eeter's Avatar
parts eeter
Replace it.
Old 11-12-2010 | 08:21 AM
red devil's Avatar
red devil
I'm a big believer in preventive maintenance so I would recommend replacing it. Question... What usually happens when something needs to be fixed and you think you can get a little more out of it? Answer... It usually costs more in the end! lol!
Old 11-12-2010 | 09:21 AM
obonaven's Avatar
obonaven
Replace it now or replace it when your broken down out on the road.
