Will I still be able to keep the same seat I currently have?
I'm thinking about purchasing this Dyna Chopped Rear Fender kit... but my question is, if I put that on my bike, will I still be able to keep my current seat? I'd like for my wife to still be able to ride with my on my bike occasionally.
http://cgi.ebay.com/ebaymotors/ws/eB...category=35561
Picture of my current bike (07 street bob) is in my sig.
Yes, but you may have to modify the new fender. The fender you want to get may not have the hole to secure your seat; so you’re going to have to drill a hole in your new fender.
**********************This is how I’ll skin the cat*********************
** do this before you paint**
Hope the info helps
- Remove your old fender and do not get rid of anything yet.
- Install new fender properly bolting down points to normal specs
- Install your seat like you normally do; but you’re not able to screw it into fender.
- Line up the seat so it is center properly like is used to be on your stock fender.
- Score/mark exact spot inside hole of seat bracket
- Step back and make sure it looks how you want it to look before committing
- Go back to your old fender and remove nylon clip that holds fastener to rear fender; save clip/fastener and do not lose.
- Take your drill bits out and fit test drill bits to the hole in old fender to get the exact or near exact size to hole. ( do the same thing if there is a smaller tab opening in that area. It probably not a prefect hole but looks like a key hole in your old fender)
- Remove new fender from bike and start a nice small pre drill at the mark you made earlier, and then work your way up in sizes to the correct size you need. ( If you need to make that smaller opening just be careful; maybe you can easily place the smaller drill bit in the bigger hole and just move up and down to copy the old fender’s hole pattern)**might can use a small file for desired outcome** Attempt to install fastener throughout this procedure; would not want to drill too big.
- Once you can install fastener and clip to new fender you should be able to do whatever you need such as paint and be ready for full install.
Hope the info helps
Why buy the "kit"? Why not just cut your existing fender. Much much cheaper. You may even find a cheap take-off fender on ebay.
Why should the MoCo make money on something people have been doing for free since the 50's/60's+.
Just a suggestion, as it is your money to do with as you see fit.
As far as painting it...I'm sure you have a local body shop that would paint it for you.
