103 work begun!
103 work begun!
I'm stoked. I just dropped a pair of heads and cylinders off at Dewey's Heads near Federal Way. My local indie had an extra set of both (in black!) so he'll just keep mine when he does the swap-out.
The proof will be in the dyno for sure, but I sure like Don @ Dewey's Heads. He is a Boeing engineer by day and makes bikes go faster by evening and weekend. He has his shop behind his house. The upside is very good pricing. $550 for the heads and $175 for the cylinders. The heads were $100 more because I gave him 2002(?) heads which have narrower exhaust ports than 2006 and newer, so more work removing material.
For those interested, here is his website: http://deweysheads.com/HDBD_home.html
Now I just have to save the $$ for all the other stuff (cams, etc.). But by Spring I'll be grinning big!
Steve
Steve
Good stuff! I'm interested in something similar for my bike, just haven't decided where to go or what route to take.
I'd like to see the results of the mods that you end up doing. My goal is to get about 100/100 torque/hp in the low to mid range.
Living in your region, I'll be following your build, so the more detail the better.
Keep us posted.
Keep us posted.
I sold my SE 259E cams on Don’s recommendation and will be ordering the Woods TW-555 cams. Here are his thoughts on it: “I am onboard with the plan but I am not sure about the cam. I have only one experience with my heads and that cam on a late model 103 and it made less than great numbers, 95/100. Based on what you are telling me I suggest the Wood TW555 cams. This will assure us of meeting the goal, if you are going to be sticking hard and fast to those numbers. The bike will be very fast, don't get me wrong, just may not reach that level. The close LSA of the Woods cams also gives the maximum torque under the curve and in the midrange where you need power in the hills. The SE cam has very wide LSA and is designed for a wider spread torque curve and yields less all over.
Either way will be OK and don't take this as a sales deal, I just assume not sell the part, but want you to be happy.”
I told him my goals were ~105-10 Hp / 105-10 Tq. I don’t want to go over these numbers because of the expense associated with needing to beef-up other aspects of the stock power train. For that reason I am going with stock valves and springs.
The KB Hypereutectic pistons (KB409C) are due to show up today when UPS comes. I’ll just ship them over to him. So he can match them to the cylinders.
I appreciate your input.
Steve
