Changing exhaust without a torque wrench
Old 10-29-2010 | 10:03 AM
Ovaltine Jenkins's Avatar
Ovaltine Jenkins
Tighten it until it breaks, then back off 1/4 turn.
Old 10-29-2010 | 10:26 AM
craigffb's Avatar
craigffb
Originally Posted by Grendel4
When you're talking about the flange nuts, I assume you'e talking about the header nuts on the studs?
What do they take, 10-12 ft-lbs? Not sure.
110-120 inch-lbs
Old 10-29-2010 | 10:37 AM
SuperglideKen's Avatar
SuperglideKen
Originally Posted by SC-Longhair
Let me ask this.....how do you get a torque wrench to fit onto the flange nuts without using a healthy extension, which will throw the amount of torque you're applying completely off. I don't have it handy but there is a formula to recalculate the amount of torque when using an extension.
I wouldn't do it.
I would just snug the nuts up good and tight. Run the bike for a bit i.e. go for a ride and then re-snug them up after a period of cool down.
Correct me if I'm wrong but I remember reading in the instructions that as long as it's a straight extenstion then the torque is the same, It's when you step down with an adapter to a larger or smaller size that it matters, I might be wrong.
Old 10-29-2010 | 10:41 AM
Grendel4's Avatar
Grendel4
Respectfully, you are.
Old 10-29-2010 | 10:42 AM
Earl IV's Avatar
Earl IV
I used my 1/4" drive ratchet (short, 4" long handle) and tightened as tight as I could by hand.
I have a bad habit of breaking bolts off when I use a bigger tools
I wouldn't worry about torque setting on flange bolts, they're not that critical and by design are built to flex a bit anyway.
Old 10-29-2010 | 10:51 AM
JRK5892's Avatar
JRK5892
GO RENT ONE! no joke... snap a exaust bolt in the jug and you will be in for a world of work to get that out... just go rent one... WHATEVER YOU DO... DO NOT TIGHTEN LIKE A MAD MAN!!!!!! THEY SNAP, HAVE SEEN IT OVER AND OVER, THAT IS VERY BAD ADVICE TO TIGHTEN AS TIGHT AS YOU CAN GET IT
i see it all the time man... please belive me
Old 10-29-2010 | 10:52 AM
Grendel4's Avatar
Grendel4
Not being a dikk, but...... You're putting what? A 3/8" stud made of hardened steel into an aluminum head, right? Finger tight from the factory, of course. Then you're putting on a steel nut and tightening it down with a 1/4" drive ratchet as tight as you can, right?
Depending on where your hand is on the drive tool (the ratchet) you could be putting on as much as 20-30 ft-lbs of torque. Depending on your own physical strength.
Those aluminum threads in the head are hanging in there on a prayer in the first place. Then a steel stud and too much torque on the nut?
I wish you the best of luck. Seriously.
Old 10-29-2010 | 11:00 AM
Earl IV's Avatar
Earl IV
Geez, overreact much?
I know how to choke up on a short ratchet, and yea, umm I know it's aluminum.
Old 10-29-2010 | 11:11 AM
ssls6's Avatar
ssls6
A normal socket extension does not impact the torque setting. An intermediate connection can if not at a right angle (like a box wrench where the torque wrench is at one end and the other is on the nut).
Take care,
Richard
Old 10-29-2010 | 11:13 AM
Grendel4's Avatar
Grendel4
Maybe you're a pro. Maybe you seriously know what you're doing. I know guys that have been wrenching so long, they have an incredible feel for when to tighten and when to stop. Maybe you're like them.
But a LOT of the DIYers on this forum aren't.
