Where does this oil come from?
Last week I noticed an oil stain on the floor under the bike. Checked where it came from and found out it must have come off the clutch cable.
Wiped off the oil and cleaned the clutch cable. Didn't ride the bike since I 've cleaned the clutch cable.
Now one week later there's an oil mark on the floor again. What could cause the clutch cable being soaked with oil?
I checked the oil filter....bottom of all engine sections are clean, dry and oil-free.
I guess you're refering to this O-ring that goes around the cable at the threaded end?
Mine looked just like yours before they changed the cable and the o-ring under warranty. the tekkie at HD told me to expect this to happen again.
Now I know......
Changed the clutch cable this weekend and found out that the cable fitting had loosened from the cover. This caused oil sweating out and collecting at the lowest point of the clutch cable.....
Now I have some more questions over here:
Question on clutch ramp coupling....
