Where dose the oil go
I have the K&N cone style breather "dont know the proper name for it"
Anyway....I go thru aout 1/2 qt of oil every couple of weeks....Now I think I know where it is going....Inside my breather, becuase sometimes it drips out of it....
Is this normal..?.. if not what can I do about it....
Thanks for all replies....
I use a spray-on type and just lightly coat the filter. A 1/2 qt every two weeks, Holy cow! The oil is only needed to coat the element and trap dust and dirt. I don't know how you can even get the filter to hold that much without dripping all over the place. You are using way too much oil... I would take the filter off and wipe out any excess oil from the inside of the breather tube. Then lightly oil the element.
Ooops...My bad, obviously I thought your were going through all that oil on your filter element.
Last edited by EricInNCa; 10-22-2010 at 11:49 AM. Reason: Mis-understood the original post.
I had a heavy breather style a/c installed. Had is the key word. The blow-by was so bad with the nice chrome breather filters that is would spray down the right side of the bike. It's not the breather's fault. It's the design of the breather system within the motor.
Doherty sells a "fix" for like $350 or so?
It does make a mess though. 1/2 qt a week is a lot of oil though.
Do some checking with the motor hot and see what that shows you.
