Rear tire and wheel-2010 wide glide
Old 10-24-2010, 08:25 PM
red devil's Avatar
red devil
red devil is offline
You don't want to run a 200 metzeler on anything less than a 5.5 wide rim. I see alot of guys running tires that are just to big for their stock rims. It's not a matter of if it will fit, it's a matter of safety. If the tire looks "sucked in" it's to big for the rim and can be dangerous in turns.
Old 10-24-2010, 08:43 PM
Sumpnut's Avatar
Sumpnut
Sumpnut is offline
if you want 200 on the rear and want to stay with 17" get a crossbones rim..sure its 6"wide..then fit the cross bones Dunni..hear theyre getting good mileage out of them..Dynas lighter so should even get more..+2
Old 10-25-2010, 06:38 PM
NuTTSaK's Avatar
NuTTSaK
NuTTSaK is offline
So I've got a 18x5.5 rear wheel, what do I need to do to get the 200 on a 2010 WG! I was about to just stick with the 180, if it will fit would like to bump up?
Old 01-28-2022, 03:42 AM
Marainkvz's Avatar
Marainkvz
Marainkvz is offline
Stage II
Hello guys, it's old topic, i know. Is here anyone, who has 200mm tire on 17X6" rear wheel? Is enough Space between tire and belt (with oem belt pulley)? Do i need pulley spacer? Thank you
ozonerainey
12-30-2020 06:30 PM
Holtdcw
05-19-2018 10:13 AM
Yukon42
07-23-2017 04:30 PM
fxstbharley2008
10-16-2011 10:21 AM
mikeurig
09-28-2009 12:26 PM
Quick Reply: Rear tire and wheel-2010 wide glide
