What is the spread distance on your sissy bar?
I have an 11 wide glide and want to see the difference between a 10/11 wideglide as upossed to an 06 and up dyna sissy bar. Since its hard to find a used one at a good price, new like 300, i want to see if what the difference is from an 06 and up dyna which are like 100 bucks on ebay complete. I want to find the one that will fit from a specific year. Please let me know what your distance over the fender is and the mounting holes from center to center as well as the year and model bike it came off of.
If there are any 2010/11 wide glide owners that took off there small black one measur that one so then i will know the exact measurement i need.
You also mention that 06-08 wg is different, that my 11 is wider. This is what i want to find out by asking others that have a sissy bar on there 06-08 wg to see what they come up with from over the fender distance to mounting holes.
My 11 wg with the tape measure over the fender looks to be like 9-9 1/2 inches across the fender and about 10 inches on the mounting holes. Again this is an estimate without taking it off.
I measured with it mounted on the bike.
The side plates (center to center on the detachable hardware) are as follows. These measurements are from one side plate to the other while mounted.
---Rear mounting point: 10 3/4" spread
---Front mounting point: 11 1/2" spread
The fender strut bolts, which hold the detachable mount hardware are 10 5/16" center to center on the bolts.
thxs bry, so the mounting spread is different from front to back? i would have thought the fender is square, thus being the same front to back. well now all i need is the mounting measurement for an 06-08 dyna. i am not looking to get a removeable one just a hard mount. this way it will just replace the stock black one. hope to hear from someone with an 06-08 model.
