Stage 1 Download On Stock FXDF
Searched but couldn't find anyone that has done only a Stage 1 remap on a stock bike-No change out on pipes or AC. Will this rich up the mix a little? Cool the running temps? Also, if a Stage 1 remap is done, does this cancel out the Engine Idle temperature Management System download? This is for my 2011 FatBob. Thanks for any info you can give.
I did the HD stage 1 recalibration with the SE Heavy Breather and SE pre 06 slip on mufflers. Bike did perform noticeably better but still ran hot around town. I did the Xieds and it richened it up quite a bit. During my 1st 500 miles without the Xieds the muffler tips inside were still clean. I mean barely any soot. After Xieds and 50 miles they were black and running rich as my fuel mpg went down. Runs great now with the set up I did.
The dealer put the stage 1 download on my 2008 Fat Bob when I purchased it and added the Screaming Eagle air cleaner (not the Heavy Breather) and the Screaming Eagle slip-ons. While I did perceive a boost in power, the heat management didn't seem to change. Like has been stated above, I put on a set of Xied's that I got from someone on this forum, and that seemed to help.
The stage 1 does not richen the closed loop mix, your ECU will try to correct to the EPA hot running lean mix. The open loop may run a bit richer, but unless you are running WOT most of the time, that's not going to help you.
I ran Xieds for awhile, although they cooled the bike, they did not fix surging or decel pop issues and was a good 3-4 mpg hit on economy. I went to a $400 TTS tuning kit and used it to adjust the bike to run just a bit cooler, fix the drivability issues, and improve the mpg. It also livened up the bike quite a bit over the Xied. Not sure if Xieds work on the 2011s.
karz10
09-29-2008 03:22 AM
Malac Frost
02-20-2008 11:31 PM
