Big Radius 2 - 1 GRRRR
Hi guys,
I've seen lots of threads regarding this but just wanted someone to reassure me.
I've been trying to get the baffle out so I can insert a smartzpart quiet baffle in.
The instructions say take the screw that holds the baffle in so you can remove it, sounds simple.
That b*stard is stuck in, am I right in thinking there is only one screw that holds it in? There's another screw further down the pipe just before the 2 become 1 but I can t imagine the baffle goes that far!!!
If it is only one screw it really is stuck, I'm starting to bend the end of the baffle with my pliers! HELP!
how big is your freezer? freeze the pipe, then after about an hour, pull out and use a hair dryer on the outside of the pipe to warm it up. The baffle will stay cold and the pipe will expand as it warms. Then tap lightly on ground and the baffle will slide right out. This is how I got my baffle out of a 2-2 BR pipe where it was stuck in there. Freezer trick often used to install press in bearings easily too.
rubiconMike
03-24-2009 05:15 PM
