2006 Dyna wide glide Occasional miss ?
I thought I had some bad gas but I get a spit or miss so to speak during operation . I looked at the fuel pressure section on the manual . I have been told that the fuel pressure regulator could be the cause . It happens when cruising sometimes on acceleration ( inititial crack of the throttle ) but none the less it's absurd ! Any ideas before I have a catostrophic melt down of biblical magnitude ! UHHHG !
In 2006 the early model dyna's had 8 deg. injectors, they also had some problems with stalling before the engine was at full operating temp. The moco has a service bulliten about them. If you you feel it is unsafe, they are suppose to upgrade the injectors at no charge to 25 deg. injectors. Could be something to check, my 06 super glide was doing the same as you described plus it was haveing the cold eng. problems 25 deg injectors fixed it, hope this helps.
